Old 06-26-2006, 05:11 PM   #3
theWeezL
theWeezL's Avatar
You do not need a different Tach, but you might need to have your speedometer re-calibrated, I dont know. It will depend on the trans your gonna use.
If your using a trans from a same year, same model (turbo or n/a) then it should be ok, but if your using something different then the gearing might be different.
____________
