This is the product I am mentioning about. Just to be
clear. Thanks for the comments so far thought!
Just need to know if this is good with turbo engines.
I know it works great with N/A engine cause one of my
friend used it on his 95 Camery and I can hear and feel
the difference in performce in the engine (nice and smooth)
but not sure if this stuff is good for use in turbo engines.
http://slick50.com/index.htm
Slick 50® Advanced Formula Engine Treatment
Slick 50® Advanced Formula Engine Treatment combines Slick 50® Protection Chemistry with a fully formulated 10W-30 motor oil to provide protection against friction and heat. Slick 50® Advanced Formula Engine Treatment is compatible with all types of motor oil, is safe for all automotive gasoline engines and will not void manufacturers' warranties.
* Contains unique & proprietary Slick 50® Protection Chemistry
* Protects against friction and heat
* Will not cause corrosion of engine components
* Comes with a 50,000 Mile Engine Limited Warranty
Slick 50® Engine Treatment For High Mileage Vehicles
Designed specifically for vehicles with 50,000 miles or more. A pour and drive engine treatment that includes a 50,000 mile engine limited warranty. Slick 50® Engine Treatment For High Mileage Vehicles works on current problems of high mileage vehicles and protects against future ones without corroding engine components. Use Slick 50® Engine Treatment For High Mileage Vehicles as part of the high mileage vehicle's maintenance to help prevent horsepower loss and protect it for years to come. Slick 50® Engine Treatment For High Mileage Vehicles helps to:
* Prevent horsepower loss
* Reduce oil consumption
* Improve compression
* Reduce exhaust smoke and hydrocarbon emissions
* Minimize blow-by
* Protect against friction and heat
Slick 50® Synchron® Synthetic Formula Engine Treatment
Slick 50® Synchron® Synthetic Engine Treatment combines the performance of Slick 50® Protection Chemistry with synthetic technology. Using Slick 50® Synchron® Synthetic Engine Treatment can help protect the life of your engine. It is compatible with all types of motor oil, is safe for all gasoline engines and will not void manufacturers' warranties.
* Uses synthetic technology to help protect against friction and heat.
* Compatible with all types of motor oil
* Will not void manufacturers' waranties
* 100,000 Mile Engine Limited Warranty
* Pour & Drive Formula
