i thought i was the only one keeping tabs on the posts, well, i've been kinda busy, its warm out in the chi, so anyways
there is a point of putting the cold air intake, but most of the intakes u see here are short-ram intakes, jus designd to retro-fit the old intake system, its a short ram for a few good reasons,
1) easy fit & replace the old unit
2) easy cleanup when it gets dirty
3) easy to reach for any maintenance
a real cold air intake uses a long tube that extends close to the ground since cold air drops to the ground and hot air rises (its science) , im working on that too, i just gotta figure out the degree bends thati need ,
im gonna put the intake in front of the car behind the foglight, im gonna use that hole where the old inlet used to go, so that way my filter is gonna be away from heat and water at the same time, that concept might change since im thinkin of taking out my foglight
