oily engine bay
I had the same problum (with the oily engine). What i found works best it get two or three cans of some stuff it is cald "gunk engine cleaner''. let the engine cool and just spray it down. use alot when you think you got it all spray more i used two cans and mine wasnt realy that bad. let it sit for 30 or 40 minute then rwash it off with a hose. do the exhust first then start the engine ant let it runn wile you finsh. try and kee away from wires and other eletricl stuff well good luck with the problum
