Carbed 7m?
I was just wondering...has anyone ever tried a carb set up on a toyota FI 6 cyl, Like the 7m ge motor? It is a big upgrade on the 80s fuel injected porsches and things like that, In both power and throttle response. The only real hard part i can see is making the distributor advane, Youd would need a controller for it because its electronic. Unless an older 6cyl distributor will fit. Id also raise the compression a little bit, to like 10:1, And i think you vould easily make 250-260hp out of the 7mge this way. And then id like to put all of this in a mk2 supra or an old celica, like a 76. Itd be cool as hell haha.
