Thread: Spark plugs?
Old 07-03-2006, 12:25 AM   #17
stumpjumper
stumpjumper is on a distinguished road
Iridium is an element. It is here because the meteor that was said to have killed the dinosaur's was made of iridium. It formed the gulf of mexico a few million years ago. There is a layer of iridium about an inch or less covering the earth that was caused by that meteor. Probably the best metal that exists on the planet. Probably not the best metal for spark plugs though. Stick with NGK. They are the best bang for the buck. All it is, like most already said, is the electric signal traveling through the least resistance. The gap provides just enough for the electricity to travel through the free space to reach the other metal to continue the charge. But, so much energy is lost in the gap that the charge is basically done when it reaches the other electrode so the charge ends at the gap. All you need is one electrode, one with good conduction, which ngk provides. Spark plugs don't do much besides conduct electricity. Clean plugs, gapped correctly are fine. Worry more about air and fuel flow, that is where the power gain is at. I believe the injectors are capable of a lot more flow then stock; get a chip to balance air and fuel flow to get the best power. Change plugs about every 15K and you'll be fine.
and i'm out.
stumpjumper is offline   Reply With Quote
