You have several options and some good resources here to find them. Use the search feature.
First and foremost, make sure your current engine is sound. If so, the you want to upgrade the intake, and exhaust. The more air you get through the engine the more HP you get. The you can begin work with the turbo. An aftermarket turbo timer will get you more boost (again, more air) and other mods to the turbo system will get you even more. From what I have heard you can get into the 300's and even 400's with the current turbo... But it sounds like you need to do some reading and research before anything else.
Good luck!!!
