Old 07-09-2006, 11:17 PM   #2
midwestmk2
midwestmk2's Avatar
Ok after studying my repair manuals wiring diagrams ive come up with this..There is no (WHITE and BLACK) wire in that system..There should only be a (RED),(RED and WHITE),and a (RED and LIGHTBLUE)..It is the (solid RED) wire that is your positive..The Other 2 are both grounds while on high beams..When you have on just the low beams then the ground is (RED and WHITE)..But the other may stay energized aswell like a positive..When testing make sure that you are using just the (RED) wire as you source and then check the other 2 as a grounds ..You may also pull the harness apart and make sure that some one hasnt upgraded you headlights to a different plug style like for Halogen lights..They did mine and i would have never found out if i wouldnt have rewired my fog lights..If you still have problems let me know..
