Please describe the dying part a little better. Does it just shut off almost like someone turned the key off, or is it more of a runs so rough it wont stay going?
Some possibilities would be, plugged cat, bad fuel filter, plugged injectors, weak or failing fuel pump, and a whole myriad of electrical possibilities. Its almost impossible to say without more information. Is the "check engine" light on? Does it run rough at any other time? Is your fuel mileage REAL bad? Do the spark plugs look clean or is there any build up on them after maybe a tank of gas.
____________
