Thread: About psi
Old 07-15-2006, 05:53 AM   #20
Isphius
Isphius's Avatar
You install the boost controller in line with the wastegate actuator vaccum line, run your car, see where it is (this is after you have a good/better boost gauge). Then turn it up or down as desired. It should come with instructions. You can get manual boost controllers for like...15$. Just search for them on froogle.
