Do you already have a metal head gasket in the first place? if you didnt get your head/block machined flat then you need to do that. If its a regular head gasket, And other than the MHG thing i just said, just look for the numerous head gasket replacement posts/websites. The mhg is the same kinda install as a regular one. I wanted to know tho...Is there any better gasket sealer to use or do you use any at all on the mhg. Ive never installed my own metal gasket before. Im sure youd use some kind of sealant tho...
