ya i don't think it's the alternator. both the ground wire by the battery and the ground wire on the firewall were good. I will check the one by the starter though, thanks. The reason I don't think it was the alternator is it went from running with air conditioner, and raidio going fine till when i turned it off i had absolutely no power. power locks use minimal power and that's how i found out there was a problem, when i went to lock up the car.
