Boost gauge will come with instructions. If its electric, You install a sending unit in your intake somewhere, And then hook up a harness and run it to your gauge. If its mechanical, It will goto a vaccum line somewhere between your TB and turbo. A manual boost controller would go inline with your wastegate acctuator and the switchy thing that tells it to start opening. It should also come with instructions
