Thread: Noooo
Old 07-24-2006, 09:04 PM   #10
j3pz
if you arent getting any spark then it sounds electrical. does the starter click when you turn the key? if not check the battery, check the lines to the started/battery. you want to check for water in the cylinders and quick cause the antifreeze will eat up the walls.
