Old 04-06-2005, 05:40 AM   #1
hangsupra
well...if you looking for the headlight relay it sure be in the fuse and relay box...next to battery...open it up...look on the left...to right... it sure be 3 of than if i right....well....the headlight relay (round) is the one that next to the fuse (Charge)....if you look from the side...there is two column of fuse...it sure the on the right at the very first one....thats above the very first fuse..thats the headlight relay....correct me if i wrong....and i will look it up tommow after came from skool....i will post it up again...
