Originally Posted by supramanocnsd
Damn your on the ball.. I'd hang wiht you and learn alot if you were in Cali...
Thank you for the kind words!
...again dead on.. stock twins.. but I would go true twin... not the fact seq... better kick more boost at low levels.. and the second turbo kick in a apex could throw the ass end out...
Agreed. If you don't upgrade to a single, the oem twins in
TTC ("true twin") are easier to roadrace than the oem twins in sequential mode. Some folks even run a setup that allows electronically
switching between sequential and TTC.
Only one minor discussion point...although TTC feels like it kicks better/harder with more boost at low levels, sequential is actually faster in the 1/4 (straight-line)...
