Old 07-26-2006, 10:49 AM   #1
72charger
72charger is on a distinguished road
Default Supra newbie questions.
High all. I considering purchasing an 87 Supra non-turbo from a guy. It has a major coolant leak and he thinks it's the head gasket despite that there is no coolant mixing with the oil. I read on here that the coolant passage can simply leak into the combustion passage and just get burned away so maybe that's what is wrong. It also has a check engine light on. Not sure why, the car seems to run fine. I am a newb to Supras but not to cars nor to turbos. I am considering buying this car and replaceing the head gasket asap, and diagnosing the check engine light. Then I'm just gonna mess around with it until I have the money to do an overhaul under the hood. How much modifying am I looking at to be running 10psi in this thing? I plan to buy a relatively stock type supra turbo, intake manifold and full turbo exhaust. What else do I need to do it. I know the compression is higher on a non-turbo motor. How much boost can this block take safely before I need to start modifying internals?
Also, are there any motor rebuild walkthroughs or guides for a turbo application? Thanks for any help you can give!
72charger is offline   Reply With Quote
