Had the same problem with my 82 . turned out to be the pick up coil located under the distributer . 1 of the 2 wires had broken and as a result the car would work perfect until it hit a certian temp then the break in the wire would seperate causing loss of spark it was like someone pulled the keys out. I would wait a while and vaarooom back in action again for 20 mins. very frustrating!!!!!!! One wire is red the other white . check both with a meter for resistance but I just pulled on them and i could feel that 1 was clearly broken . $200.00 can from Toyota . Good luck and MKII's rule!!!!!!!!!!!!!!!!!!!
