Old 04-08-2005, 02:07 PM   #7
the stev
Guest
Posts: n/a
the wires you need to splice to are comming off the back of the ignition and are in a bundle.. feel right behind the ignition and there will be a plug which is the plug you connect to if you use the harness if not have fun cuttin all that stuff up cause there is not much extra wire there
