Originally Posted by supramanocnsd
The rotating components of the driveline are...... if you wanna get tech on it a 6sp weighs 3415.. the ttauto 3425.. only 10lbs..
If you wanna get tech, try picking them up yourself. The difference is a LOT more than 10lbs. Part of the explaination of the similar overall weights has to do with the heavy oem flywheel that stays on the engine when you remove the 6spd...
