Originally Posted by Supra2NR
u wanna beat that talon?
first of all our cars are too heavy to compare with that
2ndly, u put a shot of nos in your engine without any other mods
you might as well say goodbye to that new 30k engine
new crankshaft
new pulley
new cams
maybe a new clutch
a fidanza lighweight flywheel
new injectors if you wanna run nos (i suggest, 75 shot wet)
forged pistons with coating
new rods
a metal head gasket (most important)
i think those would be enough
and you will beat that talon by a long shot
I will agree on most of the parts, But you dont need cams pulleys or the flywheel. They may help, But trying to fit the low-budget thing ha. And if only a 75 shot, the bottom end would hold up fine, just need the mhg. If more, id say build the bottom end. And remember you need traction
dont just need to mod the motor. This is a talon tsi im assuming so its AWD and about 1500lbs give or take lighter. (im exhagerating).
