Old 08-04-2006, 05:54 AM   #1
midwestmk2
midwestmk2's Avatar
Check the ISC valve and related wires..Could also just need the timing reset also..If worse comes to worse it could be a head gasket getting ready to go..They sometimes reer there heads when it is cold and the gap has time to form more than warm..good luck
