Old 08-05-2006, 06:43 AM   #2
Supra2NR
Supra2NR's Avatar
le me see where to start
ok
the 7mgte vs 1jzgte
almost the same identical engine except the 1jz has twins
you can achive this with the 7m also with the help of a custom downpipe
thier capabilities are almost the same
power is almost the same (not stock to stock of course)
but stock the 1jz has more power than the 7m
but once again it can be duplicated
7mgte vs 2jzgte
there is almost no comparison
2jz is the best engine that toyota ever made
power is no comparison
i dunt think the 2jz has the headgasket problem like the 7m (look that up)
all you need to do is port the head maybe oversized piston, and your good to go with the bolt-on power
but the big issue is the power:money ratio
the 2jz engine itself is expensive enough already
plus the only thing you can get is probly from an aristo
not the original 2jz's that came from supras
1jzgte vs 2jzgte
2jz all the way since it can handle more abuse than the 1jz
and the other stuff is above about this engines
my suggestion: see how much the 1jz conversion is gonna run you
then see how much to get a custom downpipe and other stuff so u can get a second turbo with your 7mgte
whatever is cheaper or easier go for that one
i did this researches online
this is to the best of my knowledge
cuz im also looking for a new engine
hope this helps you out
