Proper maintenance.
20w-50 in summer, 10w-40 winter.
99% of the oil out there has 'detergent' in it to help keep the engine clean.
If you change it regularly at 3-4k miles, the engine will stay clean inside.
Same goes for anti-freeze. Its cheap enough to change every other year. Helps keep the corrosion from building up.
Same with diff oil, and power steering, and tranny, too.
