That's physical.. not Tech.. and I have.... it's 10lbs... the flywheel is not the prob.... it is heavy.. but no the prob Why are we talking about this???
Originally Posted by pwpanas
If you wanna get tech, try picking them up yourself. The difference is a LOT more than 10lbs. Part of the explaination of the similar overall weights has to do with the heavy oem flywheel that stays on the engine when you remove the 6spd...
