Build list! Probably forgot a bunch...
Engine Management:
-AEM CPU
-Apexi AVCR
-AEM Wideband
Engine:
-Wiseco .40 forged pistons
-Eagle H beam Rods
-Toyota bearings
-ARP Headstuds, Mainstuds, Rod bolts
-HKS 2mm Metal Headgasket
-Stage 3 Port and polished head
-AEM adjustable cam gears
Induction:
-Custom Short runner Front facing intake manifold
-Q45 88mm Throttle body
-GT 4067R Turbo
-Tial 50mm BOV
-24x12x3.5 Custom intercooler
Drivetrain:
-HPF's Feramic full faced clutch disk w/ RPS 3200lb pressure plate
-Fidanza lightwieght flywheel
-Titan motorsports aluminum drivshaft
Exhaust:
-HPF's tubular manifold
-Tial 44mm wastegate
-3.5" Downpipe, midpipe and test pipe (Stainless)
-HPF's 4" Stainless cat back w/ 4" in/out aeroturbine muffler
Fuel:
-RC 750cc injectors
-LIPP High flow fuel rail
-Aeromotive a1000 external pump
-Aeromotive filters, 10 micron and 100 micron
- -08 line from pump to fuel rail
-Aeromotive FPR
Interior:
-Sparco Torino racing seats
-JZA70 Momo steering wheel
Suspension:
-Tein Flex coilovers
-Tein EDFC (coilover controller)
-Suspension technique sway bars
-JIC rear strut bar
-Cusco Front strut bar
Wheels:
-Racing Hart c4, 18x9f 18x10 r
-Nitto 555, 245/40 f 275/35 r
-94 Supra TT wheels 17x8f 17x9.5 r
Brakes:
-Precision brakes 13" slotted rotors front and rear
-Willwood 4 piston calipers
Other:
-Autometer Cobalt gauges
-Oil pressure
-Fuel pressure
-Boost pressure
-EGT
-Water temp
-Voltmeter
-Fuel level
-HKS turbo timper
-Battery relocated to trunk w/ Jegs aluminum sealed box
-Optima Red top battery
-Earls aluminum oil cooler with -08 lines
-Oil filter relocation kit with -10 stainless braided lines
Nate
