Old 08-09-2006, 12:42 AM   #16
kwnate
SP58GT
Originally Posted by CzA
I was also told that the bottom end of the 7mgte vs the 2jz is a little stronger stock fo rstock. I was thinking about doing a 2jz swap, but some one told me to just find the top end from a 2j and slap he ron to the bottom end of your 7m.
Peace.......
That is some gross misinformation. A 2j head will not fit a 7m block or vice versa. The 2j's stock bottom end is good into the 700whp range iirc and the 7m is good in to the low 500's as long as its in very good shape.
A 1j head on a 2j bottom end will work. It's refered to as a 1.5jz
Nate
