Originally Posted by Supra2NR
and u can use the old spot where the tems control used to go and put the edfc controller there
Follow the instructions for installing the edfc and the 4 motors.
As for the stock tems, Just disconnect the tems connectors on the tops of the shocks, hide them. Run your new lines for the edfc as pretty as possible and your done. You don't need to disable anything. You can remove the tems controller but I just left mine in. You'll still have the tems lights on the dash, but who cares?
