Thread: more
Old 08-13-2006, 11:11 AM   #11
f00g00
Remove the screws on the botom of the panel should be about 5 or so. Take the screw out of the cup under the inner door handle. Remove the two caps on the door panel that you grab to close the door and loosen the two screws there ,and there is one or two fasteners that you have to pop out towards the back then lift from the back up to remove the molding where it fits over the door and mates to the window.
You will have two connectors also, the interior light on the aft bottom and the one that plugs into the multi switch for the windows.
