If $6000 is your budget for the body work alone you should be fine. Of course no carbon fibre body... Plan on spending 6 times that to safely push the car to its limits. You don't have to spend that much, but when you're talking about 5, 600+ hp you can break stuff or kill yourself really quick. Cutting corners is not a good idea, Good luck.
Nate
