sure no problem....because....the 6mgte is usually came in turbo.....in japan....and the 6mge is not turbo....but still have higher compression then the 5mge....because it built into 3.0L not 2.8L like the 5mge....its like the mk3 supra.....the 7mge is non-turbo and the 7mgte is turbo... pretty is the same like the mk3 supra....but just that the US didnt carry the 6mge or 6mgte....because its made in japan and not in US...if you want the 6mge or 6mgte you can still get it from japan tho....
