Ok the timing was a little off. I fixed it and it runs a little better but it still idles rough. It also dies when I come to a stop. BUT now the check engine light is on. Is there a way to flash check the codes in these cars or no? I know with my eclipse I had you could turn the key on and off 3 or 4 times and it would flash the check engine light for the codes. Also with my honda I had you hooked up a wire to make a connection and it flashed the codes. Is there anything like that on these supras or do I have to take it to a shop????
