Old 08-17-2006, 02:09 AM   #2
Supra2NR
Supra2NR's Avatar
im guessing the liquid one
the solid rubber absorbs impact from movement
and rubber tends to wear off after while
the liquid , well uses liquid to absorb the force
the only way i can see it backfiring on you
is if it has a leak
but ill go for the liquid if i was you
probly provide better value to you in the long run
