Old 04-13-2005, 07:03 PM   #12
monkihead
SP58GT
monkihead's Avatar
Originally posted by hangsupra@Apr 13 2005, 11:41 AM
dont worry same over here....didnt lock my car too..... well...i got one turbo on but not the other yeah....because one of the turbo is f@ck up...so still waitin for the other one arrived....i try to upgrade the second turbo into a t4 instead of the ct26 if i can...but i not so sure about that....i not sure if the manifold would fit.....if it fit than yeah....i will upgrade the first ct26 turbo for low compression or low end...and the second t4 turbo for high compression or for high end...but i not so sure if the t4 will fit on the ct26 manifold....if not fit then i just hook up with the same one....ct26..... :P
so, how are you switching between the turbo assemblies? -for low end to high end?
monique- better off dead
monkihead is offline
