No problem I took it as a complement! end of subject.
I'm probably 5 hrs in front of you guys the time is 23.55 pm so I will keep it short. The red arrow shows the steering stop adjusting screw covered with a plastic cap. The blue arrow is the lower suspension arm. On full lock the steering stop plastic cap will make contact with the suspension arm. If the plastic cap has worn through you will have metal to metal contact.
