You can adjust the screw in the back of the trottle body a little to bring up the idle rpm and then just recheck the tps sensor when done. Im not talking about the normal adjustment on the linkkage either. The actual throttle stop can be screwed in a little after you loosen up the 8mm nut I beleive it is.
