That canister is some kind of muffler or something. Its pretty pointless. I actually eliminated mine by getting PVC and shaving down the end to fit in the original adapter, And then i used a 3" rubber coupler on the AFM end. And yes, A vaccum leak from the intake hose will cause bad idle, bad gas mileage, And a weird hesitation or shaking when you start off in gear sometimes. Check that out. But since your computer is putting out codes, something is wrong with the tps most likely.
