You dont need an upgraded turbo to drift...Of course it does make it easier with the extra power. Its all technique really. I can slide any RWD car stock. It just depends on how you drive it and what techniques you use...ie Feint, power slide, power over, E-brake, braking techniques. Also it would be a good idea to get a 2way LSD. Although the stock LSDs will be ok for now, but again, it makes for easier drifting...and try not to do it in the streets! Good luck
