AE86 and mazda miata for the acutal handling but they are both under powered. the 90 body style 240sx with a SR swap is probably the best for the money and makes enough power to continue to stay competitive once you get better. I would try to avoid the S15 model because their transmissions are weaker. the trans is the same size as the one that i have but they shoved a 6th gear into it.
