If you really want to drive your car, you can get a re-ring kit for about 300$. It coems with all bearings, gaskets, and a new set of rings. Did you take your old motor apart yet? If it doesnt need any machine work, thats all you need. Otherwise search around for a new crank and a set of rods, or even just the number of rods you need that are bad, And you have an essentially brand new bottom half, And a good hg. And then just get arp or brand new head bolts and torque them down good, And you should be good for a LOT of miles.
