It could be a thermostat or something, But definatley sounds like a BHG. Its not a hard job to replace it. You can do it in about 3-5 days if you are working alone. Even if it isnt bad, Its a good idea to replace it. And definatley use brand new toyota or arp bolts. Or studs, If you feel like shelling out the money, cause they make it a lot easier to put back together. And just use masking tape and a marker to mark where all the coolant lines, Connectors, and hoses go. Goodluck withj you supra!
