k... old trannie will bolt up to gte motor... as previously mentioned there is just the fix for the neutral start switch required
you could try on
www.supramania.com in the parts section to see if anyone has some lying around that is fairly close to your area or can ship it out to ya
just get the ecu, engine harness, engine, some rewiring required to mate the na body harness to the turbo
lmk how you get on
