Well model specific, yes the Supra Targa does tend to leak. However the leak is fixable and usually doesnt require any new parts, just some silicone caulking. Supra's are also prone to leaks at the bottom of the rear hatch glass. The seal gets worn out, and water starts to leak in to the rear hatch where it collects. From there it usually rusts out the clips holding the the rear hatch panel on, and then ends up down in the spare tire well rusting that out as well. Pull out the spare tire and look for serious rust on the floor there.
Aside from the already mentioned head gasket, the motors are pretty strong, but also already mentioned the power steering leak issues. Also the valve cover gaskets tend to leak and leave oil in the spark plug galley. Alot of time you can just tighten the screws down and get rid of the leaks.
The suspensions are pretty solid in the Supra, and I rarely see problems with them beyond needing new shocks. If the car is seriously abused it is possible it could need ball joints or even a steering rack.
Lastly, the 2 piece drive shafts are always abused and forgotten about. The carrier bearing usually needs replacing, and runs about $60 IIRC.
I think that about covers model specific issues, good luck!
____________
