Thread: Venting
Old 08-30-2006, 06:32 PM   #12
Burn N' Up
Burn N' Up's Avatar
If you have the TSRM use it to follow every vacuum line and make sure there are no cracks and they are all hooked up to the correct orrifice on each fitting, I had one switched around and blammo, ran like crap. Don't forget the ones under the intake plunem(SP?).
89Turbo 5 speed:Eibach lowered,Tokico Illumina II TEMS,All Poly Bushings,3" Elbow/DP/Cat,HKS Sport Turbo Exhaust,K&N FPIK w/ AEM Dryflow,Cooleeze ceramic coated Turbo inlet Pipe and 2.5" hard IC Pipes,Custom 2.5" fitting Spearco IC,HKS SSQV BOV,Greddy 1.5mm MHG and timing belt,Magnecore Comp Wires,NGK IR Low-temp Plugs,ARP studs,Dual Flex-a-lite fans w/ thermo switch,Fluidyne Rad,PCV VTA,Stage 3 F1 Racing clutch,Stainless braided clutch line and brake lines,Drilled & slotted rotors,EBC pads.
