Old 08-30-2006, 10:32 PM   #1
91toy supra
91toy supra is on a distinguished road
Default intake manifold has coolant what did i do wrong?
So we got all the vacuum lines connected.. and blocked a few coolant lines due to taking out the ac pump, and the power steering, but there is a line on the intake manifold more towards the front of the car.. it attachs it self to the intake manifold and has a few vacuum lines that run parallel to it but are connected together by pipes.. the vacuum lines run up to the connectors it needs to be in.. but we have a coolant line that runs into the intake manifold and we seeled off on the other end with a screw because it did not connect to anything..
now when i go to crank the motor over white smokes shoots out the intake manifold.. we found out it was coolant.. any idea what im doing wrong here??
this isnt my motor, but i circled the line i was talking about .. if you follow that line.. thats the line we cant figure out where the other end goes..
can you guys helP??
THanks
91toy supra is offline   Reply With Quote
