09-02-2006, 01:16 PM
#2
Supra Owner
Originally Posted by supraline
Hi on my mkiv tt the AC dont work i removed the radio Panel and took out the AC Controll panel and all of a sudden after pluging the 2 orange wires back in all i see are the lights i press buttons nothing works on it im not sure what happend can anyone tell me if i poped a fuse or something if i did pop a fuse from where and how can i change it? thanks
Are you sure your orange connectors are plugged back in properly? Also note that it's possible that the solder joints on your a/c control panel got cracked if you bent the panel while removing it. If you have the TSRM, I believe there is a troubleshooting section for your a/c system...you should be able to simply follow the troubleshooting steps listed to diagnose the problem. In addition, these links may help:
http://www.mkiv.com/manual/1995_elec...95elec_022.JPG
http://www.mkiv.com/manual/1995_elec...95elec_228.JPG
http://www.mkiv.com/manual/1995_elec...95elec_229.JPG
http://www.mkiv.com/manual/1995_elec...95elec_230.JPG
http://www.mkiv.com/manual/1995_elec...95elec_231.JPG
http://www.mkiv.com/manual/1995_elec...95elec_232.JPG
http://www.mkiv.com/manual/1995_elec...95elec_233.JPG
http://www.mkiv.com/manual/1995_elec...95elec_234.JPG
http://www.mkiv.com/manual/1995_elec...95elec_235.JPG
http://www.mkiv.com/manual/1995_elec...95elec_236.JPG
http://www.mkiv.com/manual/1995_elec...95elec_237.JPG
http://www.mkiv.com/manual/1995_elec...95elec_238.JPG
Life begins at 30psi.
