Originally Posted by supraline
Thanks i fixed the problem! you were right the 3 orange wires that go to the ABS.. 1 of them was lose i pluged it in and works great! and do you know where they sell replacment lights for the AC panel the ones that you turn and pull out the little green ones?
Most likely your lights aren't burned out...it's cracked solder joints. Just re-flow the solder with a soldering gun and they'll work again.
