Thread: damaged engine
Old 09-05-2006, 04:38 PM   #16
pwpanas
Supra Owner
pwpanas's Avatar
Originally Posted by 2JZ Beast
well maybe it's stroked then, cause i was told it's now running 3.3 liters, did u read my spec sheet i posted some time ago, cause it seems like you know what you talking about, to see what was done, do you drag yours, what time you getting
Is this the spec sheet? http://www.toyota-supra.info/forums/...7803#post17803
Those specs do NOT mention a stroker kit. Based on those specs, you've only got about 3.07L.
If you're interested in comments, you did not need to get your engine built for 700hp. Also 700hp won't get you into the 9s...but a 76mm turbo will put down FAR more than 700hp...and far more than 700rwhp too.
That post doesn't show what kind of transmission you're running.
Which "racing oil pump" did you go with?
My Supra is built for roadracing & top speed, so no dragstrip times sorry...
Life begins at 30psi.
