Ok i did some research and all i came up with was this..Here is a link for a celica with a Mopar 318..Now the Celica was just about exactly the same as the supra except the whell base was a little shorter..So your cross member will be farther forward about 1-2 inches so you shouldnt have to do the floor and firewall mods..Also you will have more room from the crossmember to the rad support..Here is also some pics of a supra with a V8 TPI out of a corvette..
Link: http://www.toyoland.com/cars/celica-v8.html
Pics:
