Old 09-09-2006, 09:26 AM   #6
f00g00
Default Its possible
The ISC valve which is right next to that area has coolant running through it so its possible its leaking in the valve and contaminating the system with coolant.
Its easy to remove and check with the engine cooled down just make sure you have a gasket handy or have gasket material on hand to make your own. If it has been leaking there the coolant would probably damage the old gasket.
